Author Topic: Wanted: Door Hinges  (Read 275 times)
DannyPancho
Wanted: Door Hinges
« on: November 06, 2020, 12:52:50 PM »
Hi everyone,
Some years back I replaced the door pins and hinges in my drivers side door to correct a fitment issue with the door itself, and it helped for a while until the door started falling again - i recently decided to take the door off to see what the matter was but annoyingly, the pins had vibrated out of place and were blocking the removal of the hinge from the A pillar!
Long story short, i had to cut the hinges up.
does anyone have two door hinges lying around? Or know of anywhere i can get some cheaper than ricambio  ;D
Thanks peeps
Fiat 126 DeVille
michaelodonnell500
Re: Wanted: Door Hinges
« Reply #1 on: November 09, 2020, 03:21:25 PM »
Do you know if they are the same hinges on fiat 500 doors?
I may be able to help if that is the case.
Rust does not discriminate
Njkip
« Reply #2 on: November 09, 2020, 03:47:05 PM »
There's a guy on eBay stripping and selling bis parts....I just got some wheel trims from him....he might be worth a try...🤷‍♂️
DannyPancho
« Reply #3 on: November 10, 2020, 10:43:10 AM »
Thanks for your suggestions - I honestly don't know if 500 hinges are the same ::) thankyou for the offer regardless!
And
I found the guy you were on about on ebay - the doors and hinges are sold  :cry:
Fiat 126 DeVille
michaelodonnell500
« Reply #4 on: November 11, 2020, 09:25:22 AM »
I'll take a few measurements and see if they match.
Anther option is to try one of the facebook fiat 126 groups. Change your request to rotten door, rather than hinges and you might get a bit more luck
Piotross
« Reply #5 on: November 12, 2020, 11:30:56 AM »
Can you show a photo of part you need ?
DannyPancho
« Reply #6 on: November 16, 2020, 11:06:06 AM »
Hello again, sorry for not replying sooner.
Piotross - Below should be a picture of the hinge i am after (x2 hinges if possible)
Thanks again  :)
Fiat 126 DeVille
Piotross
« Reply #7 on: November 26, 2020, 08:10:33 AM »
This part is completely unavailable at the moment
126blackbird
« Reply #8 on: November 27, 2020, 04:05:18 PM »
It looks like they come as part of the door, if you want these someone is going to sacrifice a door for you
