Author Topic: Red Wire  (Read 1600 times)
Ricksy1121 and 1 Guest are viewing this topic.
Iffy650
Red Wire
« on: October 03, 2020, 08:10:22 AM »
Rebuilding my 1989 126 and i have this red wire that i cant locate where it connects to.
Must be something close to engine. Anyone know where it goes? See photo.
Guldbergdk
Re: Red Wire
« Reply #1 on: October 03, 2020, 08:23:59 AM »
I recall there is a whole wire diagram ib the subscriber section of the forum. With wire colors etc. A little detective work there migt yeild something. Or try and run the car and see if everything is working ::)
michaelodonnell500
Re: Red Wire
« Reply #2 on: October 05, 2020, 01:44:47 PM »
That looks like the starter solenoid wire.
You will have a wire bolted to the starter to provide cranking current. The one that is loose takes the feed from the ignition key.
Rust does not discriminate
Iffy650
Re: Red Wire
« Reply #3 on: November 15, 2020, 10:16:31 AM »
Thanks Michael,
I have a maroon wire connected to the starter motor which corresponds with the wiring diagram.
So, I'm still trying to find out where the red wire goes. Cant locate it on the wiring diagram.
Would great if anyone knows wher it connects?
Re: Red Wire
« Reply #4 on: November 15, 2020, 12:33:00 PM »
Photo please?
