Author Topic: interior panels and engine fired!  (Read 111187 times)
Re: Stuey's 126 Painted (YAY!)
« Reply #465 on: December 21, 2016, 09:01:37 PM »
Hi Danny I completely forgot about this I'll get the measurements tomorow, that aside all the plastic windows are in-
I have modded the lock buttons to be the "door handles" you simply pop your finger through the hole and press the button to open the doors-
More soon!
DannyPancho
« Reply #466 on: December 26, 2016, 09:43:16 PM »
Not a problem! I forgot i asked if im honest!  ;D thankyou though!
Great work on your car! Im jealous!!   :P
Dan
Fiat 126 DeVille
« Reply #467 on: January 04, 2017, 06:49:13 PM »
repeat post!
« Last Edit: January 04, 2017, 09:55:10 PM by stuey »
« Reply #468 on: January 04, 2017, 07:12:22 PM »
You can buy them separately but you will need to buy a set of coilovers to go with it.
danny here the basic measurements between the holes in cm and the length of the arms to the bolt hole for the a arms if you need any thing else let me know-
whilst waiting for the fuel system fitting and doing the wiring i decided to cut down my lip spoiler, I bought a mk golf (not gti) lip spoiler and cut 7 odd inches out of the middle, its currently drying in the garage after I glassed back in one piece...
« Reply #469 on: January 08, 2017, 12:35:14 PM »
I fitted the lip spoiler today and it looks great really happy with it-
DannyPancho
Re: Stuey's 126 Lip spoiler fitted
« Reply #470 on: January 13, 2017, 03:08:15 PM »
Thankou for that Stuey, that'll help me massively!
Cheers  :D
Fiat 126 DeVille
Re: Stuey's 126 Exhaust and urethane!
« Reply #471 on: January 15, 2017, 05:03:17 PM »
Today I put the stainless exhaust on the car and refitted the engine spring with the urethane bushes-
Fat650
« Reply #472 on: January 16, 2017, 10:00:42 AM »
I like your build mate. Looking good.
I just noticed the front cross member setup that you plan to run and cant help but think you will run into the same issue as i did where the calipers will hit the a arms when you turn the wheel.
If you want, have a look at what i have had to do to overcome the issue.
My page is:
https://www.facebook.com/FSM-NIKI-Project-1210331735674477/
I also have a thread on here warning about the issue.
Just on a side note, what wheel and tyre size are you running?
« Reply #473 on: January 17, 2017, 09:00:52 PM »
Thanks for the info fat650 I haven't got round to fitting my new front end yet but if it's a problem at the moment ill know what to do. I have 13x5.5j with 175/60/13s but I will be running 13x6j I haven't decided on tyre size but it will be a lower profile that before as I want to increase clearance.
Fat650
« Reply #474 on: January 18, 2017, 07:34:35 AM »
Cool
what sort of offset are you running? And do you plan to run flares to accommodate the 6 inch wheels?
« Reply #475 on: January 18, 2017, 07:40:27 AM »
I'd have to check the offset I can recall what it is- the arches have been rolled and the inner wells were clearenced slightly on the inside and welded up so theres no lip and a test fitting I did before paint showed they would fit with the old tyre size (only just!) so the slightly lower profile should make it all fit nicely.
« Last Edit: January 18, 2017, 07:41:58 AM by stuey »
Fat650
Re: Stuey's 126 Lip stainless exhaust fitted.
« Reply #476 on: January 18, 2017, 08:08:29 AM »
I'm sizing up a set of fiat 500 pop 14 inch steel wheels atm as its my only option and it seems the offset will need to be modified to clear my coilovers at the front and the a arms at the rear. I'm really keen to find out what sort of offset and max tyre width you can run in the standard guards.
I've read your thread but cant remember, do you have any engine swap plans?
« Reply #477 on: January 18, 2017, 09:41:00 AM »
Ill do some measuring when i get a chance. Im not swapping the engine but plan on beefing up the transmission and driveline then putting a small supercharger on it.
« Reply #478 on: January 18, 2017, 06:07:18 PM »
Not sure how you would beef up a 126 gearbox or why you would want too when Smallcox runs 100+ hp through a standard box with a 5th gear conversion  :)
« Reply #479 on: January 18, 2017, 09:23:40 PM »
Wrong words perhaps rusty, I'd like a 5 speed conversion. Myself and I would like to fit updated uj's
